cub cadet I1050
ACF
cub cadet model I1050 number 17af9bkp010, this mower turns to the left but will not turn to the right, the gears next to tires good, when you turn the steering wheel to the right will start turning then it free spins, am i looking at internal problems in the steering assembly, any comments or suggestions would be very helpful thaanks
The steering sector gear and steering wheel gear are probably worn to the point of causing this issue. Lower the deck and look underneath the mower and follow the steering wheel rod down to locate gears.
Looks like a nasty steering system to work on. First is both wheels not turning to right or is it just the RH wheel. THis would narrow where in the steering gear box to start looking at.
turns to left it is a hit and miss as far as turning to right
found that the steering shaft was damaged where it fit into the steering gear assembly thanks for help
