I'm At A Loss!!!
jetsticks
I have a Hustler Sport 48" ZTR with a 21 HP Briggs and Stratton engine. I noticed after mowing I had a bad oil leak coming from the oil pump to the carburetor. I inspected the line and saw no tears or holes so I thought it was the oil pump. I bought an OEM oil pump and installed it. The next time I mowed it was leaking again. I will say that when the mower is not engaged and just idling I don't see any leaks but after I engage the PTO oil starts to drip from the line that goes from the pump to the carb. I replaced the clamp on the pump with a hose clamp to make sure the old one wasn't too lose. Could the line have a pin hole or something? I did take it off and checked by putting an air hose in it and listening for any air. Any help would be appreciated.
@StarTech I am going to assume that this is a single cylinder OHV with a fuel pump, and he has oil leaking from the fuel pump vent. But to the OP we need the model and type so we can determine what you actually have.
That what I am thinking but want to be sure. Or it can even be the breather hose.
jetsticks
Sorry guys. Got bogged down with flooding. Anyway, the B&S model 929133 540cc 21.0 J1940 (?). I tried to send a couple of pictures but I don't know how to make them smaller so they could be sent.
Recheck your model number the 929133 is not correct. All numbers should be stamped into the valve cover if OHV.
Model posted is the Hustler model number. Appear to have a Briggs 331877-0117-G1
jetsticks
Could this be the model number? 331877-0117-G1
Thanks StarTech!
