Troy bilt tb30r 13A726JD066 2019 carbulator linkage diagram
Mr.Farrell
  • / Troy bilt tb30r 13A726JD066 2019 carbulator linkage diagram
Hi farrell here i dismounted the crbulator spray som clener and put it back but dont remember how the linkage goes on thanks in advance
Not direct help but take pics next time so you don't forget. 📸
Mr.Farrell
Thanks for your advice, on the other hand anyone has this mode to share a pic on the carburetor linkage
Folks he has a MTD 7T84JUA engine. I don't have a manual on this engine.
It seems MTD has made several new engines and haven't release publicly the service manuals.
Mr.Farrell
Thanks il keep looking
Mr.Farrell
Hi farrell here found the issue with the carburetor high rpm when dismount the carb. Broke the throttle return spring and dont have replacement part num.
I believe this what they call the idle spring.
PN 951-15733
