Skippydiesel
- Nov 29, 2020
- Threads
- 13
- 274
Some older engines fuel metering & supply systems will be damaged by ethanol in the fuel.- - do not use ethanol blends.
Many modern engines will run just fine on ethanol blends (see owners manual for recommendations).
Long Term Storage (in excess of 2 months)
If there is any danger of fuel aging to the point of "varnishing" the fuel metering system or separating out (free water);
Drain ALL the fuel from the tank to the metering (injectors/carburettor bowl). This is the cheapest, surest way of minimising in storage fuel systems.
When ready to use engine again, refuel with nice clean, fresh fuel - make sure its being supplied to the metering system. (Freshly charged battery, if required) start in usual way - almost all engines will spring to life without any problem.
