bartameous
I believe the right side axle seal is leaking, onto the drive belt causing it to slip when warm. Is this a easy fix? I'm of the belief, if one is leaking, the other is probably going to start. The right side looks like it might be a easy fix, but the left side, I'm not so sure. Anyone have any info on this? Please help.
