mbratch
I have an Ariens SportZoom 1232 I've had since 2004.
Just recently I noticed the blade does not stop if I turn off the PTO. I checked the PTO switch and it appears to be working properly. So I think this means the PTO clutch is stuck in the engaged state. That seems odd to me as I would expect typically if they fail, they fail with the coil de-energized which would disengage the blade.
Has anyone experienced this before? I thought I'd ask about before buying a replacement (and probably expensive) PTO clutch.
Thank you!
Thank you!
