sivicman
I have a T2290 that makes noise when you disengage the brake. If you look underneath with the motor running and push down the brake pedal it stops. You can see the belt moving when brake is released. Belt stops when you push down on the brake and the noise goes away. I'm wondering if this is a pully bearing going out. I can't find the warranty for this mower. I have 110 hrs. on the unit.
