SeniorCitizen
- Aug 28, 2010
- Threads
- 145
- 2,327
BTW , this is a original J D blade from a 350X and it's no harder to file than mild steel . So much for heat treatment .
I have only found one company that made proper heat treated blade and I dont have the old mower that they fit on anymore. Soulution. Make a Burn Barrel for your yard and heat treat the new blades yourself. you can measuire the temp of the steel and then quence in a 5 gallon bucket of used motor oil then sharpen them. Might want to do a dozen at a time as its another yard maintenance task thats a pain in the butt.View attachment 68904With a extra vise a quick jig to hold a blade so the hand grinder can grind on the top edge . This blade gets about 30° and three 2 xs gives that angle close enough .
This can harden a blade but only if it has the right steel .I have only found one company that made proper heat treated blade and I dont have the old mower that they fit on anymore. Soulution. Make a Burn Barrel for your yard and heat treat the new blades yourself. you can measuire the temp of the steel and then quence in a 5 gallon bucket of used motor oil then sharpen them. Might want to do a dozen at a time as its another yard maintenance task thats a pain in the butt.
