Echo PB-403T new coil still no fire
skippymud
Hello All
Echo PB-403T Back Pack Blower no spark issue
Now has a new (aftermarket) coil, I've changed the plug and the flywheel magnets appear solid. Still no fire. Two bad coils, ORIG OEM and aftermarket product? I welcome any good words
Ken
Unplug your black kill wire from the coil and recheck for spark, you could have a short to ground on the kill wire or a problem with the switch.
Strange. I took care of both these possible issues. Gapped with card and disconnected the kill wire. I am thinking bad second (aftermarket) coil. I am going to exchange it for a replacement. Thank you Joed, Scrubcadet (a Taryl reference - Nice touch) and AMZ
You are holding the spark plug base metal to touching the engine metal ? This completes the circuit. Maybe try & test again.
Hi 7394. Yes, base touching the head. The pic is just to show the machine. Got to be bad coils
Regurgitating this thread. New coil (3rd one including the ORIG OEM), still no spark. Really weird. In the case that it is/was the plug, I did try a CJ8 in-place with each coil. Nothing, nada - Whit's end. Please share anything else I should be checking. I disconnected the kill wire by the way b/c I don't need a simple mistake being the culprit
