ISX2200 torque for upper spindle nut?
chinookmtp
Does anyone know the torque for the top spindle nuts (5025405, 3/4-16 Hex) #8 on attached diagram for ISX2200 Mfg. No: 5901845 ISX2200 Series w/ 61" ICD Mower Deck? Or just use the standard torque formula?
When spec is not present we use the standard specs. In this case the 3/4-16 grade 8 nut is torque to 35 ft/lbs [420 in/lbs] per the chart that is in the IPL.
chinookmtp
Thanks, I was able to remove nut and spacers, however, pulley is a different story. It seems to have a slot for a "key" but I don't see one. Will I have to get some sort of puller to remove the pulley? (ISX2200 Mfg. No: 5901845 ISX2200 Series w/ 61" ICD Mower Deck) posted photo
Honest Abe
a puller and a blowtorch, and wear gloves
Davenj4f
I have had some pulleys so tight I destroyed them getting them off. Had to order new pulleys. Ever since, I use axle lube on the spindle shaft and have never had problems getting the pulleys off after that.
SeniorCitizen
I've seen heat applied in the wrong location so many times it's pathetic . Example : heat applied where it's stuck at the hub . Wrong because the outer diameter hasn't expanded . Heat the outer diameter and the hub will be drawn from the shaft . It makes no difference ; that pulley or a bull wheel that weighs a few hundred .
Honest Abe
Free Download Microsoft Windows 8.1 Pro (x86/x64) Pre-Activated Multilingual ISO
Looking for a powerful, touch-optimized operating system with robust security and modern features? Microsoft Windows 8.1 Pro is the perfect choice. This OS, part of the Windows NT family, revolutionized user experience with its Metro design architecture and seamless functionality for desktops and tablets.
Overview of Windows 8.1 Pro Pre-Activated
Windows 8.1 Pro, released in 2013, brings significant updates and performance improvements. With its pre-activated feature, you can skip manual activation and start using it immediately after installation.
Key Features of Windows 8.1 Pro
Customizable Personalization: Modify themes, backgrounds, and even use animated wallpapers to suit your style.
Enhanced Security: Features built-in Windows Defender and additional tools to safeguard your system from malware and threats.
Modern User Interface (UI): Enjoy an intuitive interface with easy access to apps, split-screen multitasking, and streamlined navigation.
Pre-installed Apps: Includes essential tools like Mail, Calendar, and Photos for productivity on the go.
Microsoft Office Integration: Comes with a one-year subscription to Office 365, providing access to Word, Excel, PowerPoint, and more.
Additional Highlights
High-Resolution Display Support: Optimized for devices like the Microsoft Surface Pro to deliver stunning visuals.
Return of the Start Button: Enhanced usability with the reintroduced Start button for quick access to programs.
New Apps: Includes apps like Flipboard and Facebook for a more personalized experience.
System Requirements
Processor: 1 GHz or faster with support for PAE, NX, and SSE2.
RAM: 1 GB (32-bit) or 2 GB (64-bit).
Storage: 16 GB (32-bit) or 20 GB (64-bit) free hard disk space.
Graphics Card: DirectX 9 or later with WDDM 1.0 driver.
Display: Minimum 1024 x 768 resolution for Windows Store access and app functionality.
Why Choose Windows 8.1 Pro?
With its modern UI, robust security features, and seamless multitasking capabilities, Windows 8.1 Pro offers a dynamic platform for both personal and professional use. Its support for high-resolution displays and pre-installed productivity tools ensures a top-tier user experience.
Download :https://geexster.com/free-download-microsoft-windows-81-pro-x86x64-pre-activated-multilingual-iso
Joined Dec 20, 2024, and hopefully expelled Dec 20, 2024.....
Davenj4f
I use an impact wrench to tighten the nut, but not excessively. Had problems doing it with a breaker bar or ratchet. Also, there is a key. I have destroyed pulleys getting them off, and the dealer told they have had that same problem. Once I get them off, whether I can reuse one or a new one, I lube the shaft and pulley with axle grease. I never have another problem getting the pulleys off.
BenryNJ
35 ft lbs is for a 3/8 nut. The pulley not on the spindle should be at least 180 and blade bolts at 120.
