Cub Cadet XT2 deck height adjustment?
Rickcin
The mower has the normal pre-determined cutting height and most are all too low while the the last (highest) notch is used most of the time.
Would a know if I could raise the deck so that all of the pre determined height woul be a quarter or half inch higher?
Check the deck hanger brackets at the rear of decks will be one or two bolts that can be adjusted. Then the front hanger bolts needs to be adjusted. Make sure all tires are inflated properly and on level concrete. Adjust from of deck 1/4” lower than rear.
