Scag freedom z starting problem
The owners manual indicates the SFZ52-26BS came with a Briggs 44P777-0117-E1 engine. Now this should those that is troubleshooting the problem. Al ot question will be asked and several things suggested. Meanwhile I got to get to my shop this morning myself.
sailingharry
An engine needs 3 things to run -- fuel, compression, and spark. If it runs (and can be coaxed to STAY running) on ether, it has the last two. The makes it easy -- it's fuel. Clogged fuel line, bad fuel, or dirty carb are the likely culprits.
