Tips for Changing Oil without Spilling!
Do it the Tommy Chong method. Garden hose and suck it out with your mouth.
SeniorCitizen
Changing oil when hot and tipping a engine is BS .
Skippydiesel
Well it works for me.
Just have to plan ahead and have your waste oil pan in the right position when you tip the mower/pump/compressor/generator. Depending on the location of the fill point, it may be helpful to have some blocks to steady the machine on, or a handy wall to lean the handle against - been doing it this way for the last 30++ years.
Get a HF hand pump. They're $7.49.
Having saved purchasing a "HF hand pump" I now feel rich and less cluttered.
The hand pump will fail at some stage, probably sooner rather than later (@ $7.49), just as you want to use it to change the oil - why bother go the KISS way.
SeniorCitizen
I agree with KISS , and it just doesn't get any better than this .
I can understand a repair business having the best fastest / equipment , but me as a DIY-er I'm not concerned about time . Concerned about a complete drain ? Pull the plug in the AM because it drained to the sump all night and I guarantee you won't burn yourself with oil .
If you've seen a engine fail because of draining the oil like above , put a cup of diesel in and it'll drain while you change that filter .
7394
Reminds me it's time to service my air compressor. Thanks.
