If the camshaft timing mark is aligned correctly, and the flywheel key is not partially or completely sheared, then the timing on engine is spot on.replaced crank case cover and gasket the timing marks were right on adjusted valves but timing is still off some where sv600
that's what i thought as well but something somewhere is not being cooperative i thought maybe i was over looking something it is puzzlingIf the camshaft timing mark is aligned correctly, and the flywheel key is not partially or completely sheared, then the timing on engine is spot on.
thank youIf the camshaft timing mark is aligned correctly, and the flywheel key is not partially or completely sheared, then the timing on engine is spot on.
hard turning over like the valves needing adjustmentWhat's going with it that makes you think it's out of time?
