Part number mystery!
Bearrepair
Hello all i have a 26hp kohler engine that i need help finding the starter for. The parts diagrams all list the starter but only give the part number for the non solinoid shift version where thats the one i need.
Craftsman version
Ps-sv735-0016
Most of the courage twins used the non solenoid shift starters. If you are looking to do the conversion to the solenoid shift starter version see this thread
Which has the part number for the solenoid shift starter that I used on the SV740 conversion.
Bearrepair
It was what i just pulled off the engine so its not really a conversion i can see the part on diagrams on some of the vendors is use but it does not list what it was hopefully the one you linked will work for me thanks!
Craftsman version
Ps-sv735-006
Go back and check your spec number you are missing a digit. And Kohler OEM starters normally have the part number on the starter housing.
Bearrepair
Yeah i missed one on the thread post my bad i thought i attached photo tho! Ill hafta fix it in a sec
Can't find any specs that used the solenoid shift starter on the SV735, But was used on one of the SV740 and 3 of the SV730.
Bearrepair
I got home finnaly and went to take a picture resized due to the file was too big but this is what was installed on the engine
VegetiveSteam
If you’re needing a solenoid shift starter, it’s part number is 25 098 11-S. That number is probably superseded now but that will be a good starting place.
The 25 098 11-s supercedes to 25 098 20-S which supercedes to 25 098 21-s which brings us to the current 25 098 24-S
