Southerner
- Jun 19, 2019
- 15
Is there a way to find/get the model number for my Craftsman (MTD made) 159cc self propelled push mower? The model sticker came out a few years ago. There is a metal MTD tag on the side of the BS motor but it only tells what oil to use.
I drug it out yesterday to mow the yard and the wheels would not turn. When I tried to engage the handlebar levers they went very limp. I figured it was the gearbox and spent over 2 hours today trying to get the gearbox cover off (there are 9 bolts holding it!). When I got it off it looked like the gearbox and handlebar lever were working as they should but because the throttle cable was limp I could not even try to start it (very hard). When I pulled on the wire in the throttle cable sheath...it came out! yes the stainless steel cable had broken in the sheath despite using oil in it. Now I have to find a replacement throttle cable but need the model number to do that. Any suggestions?
Thank you.
Thank you.
