On the back ignition switch you attach the meter's 12v lead to terminal A1. Note keyswtich symbols are not on the switch as the diagram but it is the same switch internally.Thanks.
Another queston.
I want to add a mechanical hour meter so need to know which wire out of the ignition switch becomes live with the key on.
I can't find the wiring diagram on line.
None was included in the info packet that came with the machine.
Thank you!On the back ignition switch you attach the meter's 12v lead to terminal A1. Note keyswtich symbols are not on the switch as the diagram but it is the same switch internally.
