Craftman Generator 6300 watt 11 HP
jono252525
Craftman Generator 6300 Watt with a Briggs Straton engine 11 HP , The model is 10T802 and the Type is 1130 B1 and the Code is 08031354
I rebuilt the engine 2 years ago and it run fine and it was use for 5 days in a row last year with no problem.
But there is a small thing that it always did and I wood like your opinion.
The generator with no load, it sound like a very small ignition spike in the exhaust sound, but if you put a load it disappear.
mechanic mark
With engine cold adjust valves to specs. page 33 in operators manual above.
fuel knock?
