You said the blades come on okay. Then nothing happens, not sure what that means then engine dogs down. Confused.
Yes I have done the that several times. Pull the engine cover and blow out the dirt & clippings.
It's not an engine problem, it's the PTO to the mower deck that's messing me up. Sorry about the confusion.
Not all three things happen at the same time. Just one of them. And I never know which one.
When I pull the PTO switch to on, one of the three things I described will happen. Not all of them. I never know which one will happen...All okay, and mower deck runs as normal, or one of the other two things, Mower deck does not turn on at all, or turning on the PTO switch drags the engine to a stall. The PTO switch (to the Mower Deck) seems to have a mind of it's own. After I trailer it from one place to another, I never know what's going to happen when I pull up the PTO switch to turn the mower deck on.
