SeniorCitizen
- Aug 28, 2010
- Threads
- 147
- 2,335
If it will crank and start the engine don't do anything but maybe clean the terminals and cable ends with sandpaper until at least 1 area shines as new metal . Your mower will take care of any decline in volts , it's made to do that . If it is one that takes water check that and if low add distilled water .Google may be your friend on the water subject .Ok thanks. Just one last question: if I take dead battery to autozone and they test it and say it's still good, I will have to take it home and put on a charger to fully charge right?
