7394
- Sep 5, 2014
- Threads
- 84
- 4,795
That is definitely TOO tight. That online spec is NOT correct. I spoke to a Kawasaki Tech on my previous Kaw engine about this specifically ...Each cylinder brought to TDC,
Each cylinder brought to TDC, valve clearance set to 0.002" per manual found online. That sounded a bit tight to me, I thought it would be more like 0.004"-0.006".
True spec is .004 - .006. Re-adjust to intakes @ .004 or .005 & Exhausts @ .005 or .006
