Part # needed....
JoeKarpowski
Good morning,
I'm still in need of the part # for the small belt that goes around the pulley underneath the engine of my SS5000 zero-turn, model #74631. Thanks!
Motion drive belt PN 119-3321 V-BELT [A SEC 64.1 EL]. Also highly replacing that small flat idler pulley PN 106-2176 as the bearing in it tends to fail a lot. Not as bad as the small 2 inch one but still would not hurt to replace it.
Thank you!
