Burned up yellow wire from starter solenoid John Deere 160
stbird
  • / Burned up yellow wire from starter solenoid John Deere 160
I have a John Deere 160 with Kawasaki FB460V engine. The yellow wire coming from the starter solenoid melted down and I can’t figure out what it connects to. Can anybody tell me? Thanks for any help.
Steve
If it is coming from the solenoid, it probably is going to the switch. Please post the tractor model number, behind the left rear wheel, and we should be able to find you a wiring diagram.
stbird
Here it is
stbird
Here is where the burned wire connects. It is yellow
stbird
Got it figured out and fixed. Once I took the starter off I found the wire that was burned behind it. Running like a champ again. Thanks!
Now here a good question. What cause it to cook the wire in the first place?
1madmouse
Everyone should come back with a follow up so we can store that away for the next diagnostic event. That way we know if what you were told worked or why it happened. Would be nice anyway.
Gord Baker
A dead short by the looks of it due to grounding through worn insulation. Glad you have it repaired.
stbird
It appears the coating was stripped off the wire behind the starter and grounded the wire. It lit up very impressively! I thought the engine was on fire for a moment.
