Jimmy the Lock
I recently purchased a 2023 Spartan Mower RZ-HD 54 in that has a Kawasaki FR691V 23 hp engine.
I'm seeing that apparently they are saying to use 10w40 ???
Oil change kit for Kawasaki engines at:
spartanzeroturnparts.com
I know in the automotive world 10w40 is not recommended because it allows for more engine wear and a lot of other mower engines use 10w30
Does it hurt anything to go ahead and use Amsoil 10w30 which is full synthetic.
The OEM oil provided in the Oil change kit for Kawasaki engines is a 10w40 synthetic blend
Or, should I use their 10w40 synthetic blend for the first oil change (recommended at 8 hours use)... and after that switch to Amsoil 10w30 full synthetic?
Kawasaki Oil Change Kit
Spartan OEM oil change kit; contains genuine kawasaki filter and oil; maintains warranty; Kawasaki engine;
