- Feb 19, 2020
- Threads
- 114
- 12,402
Really depends on the mower setup. Some you can change without pulling the transaxle and others you have to pull the transaxle. Some have rod running across the pulley that makes impossible to remove the pulley on some models. Also the tension on the belt must be removed in order to do this.I found out what the problem was. That nut holding the main pulley down came loose. I tried tightening it up and it ran better but still won't pull a slope. I'm thinking that hub mount is stripped and I need another one. Any idea how I replace that? Can I do it from the top or will I have to drop the tranny?
For the pulley it has a star drive that may have been damaged and it mating hub may also have been damaged. We only a few hundredths of an inch thickness.
