LawnWizard
- Nov 17, 2021
- 106
Troubleshooting a no spark issue. Engine spins over. No spark. Both coils test good, checked for sheared crankshaft key, tried a known good voltage reg / rectifier, new plugs. One thing that I do NOT know on Bad Boy / Kohler is which (if any) safety switch will allow the engine to crank but cut off the electric to coils etc? Likely causes for no spark? Ign switch? Relay? Any suggestions are much appreciated.
