I've transplanted a 21hp briggs and stratton from a craftsman ltx1000 to a craftsman gt5000 with a blown kohler 25HP with an electric pto.
Everything matched up pretty well, other than a couple of electrical connections and the shaft pully set up.
The briggs and stratton has a 1" shaft vs the kohlers 1.25" shaft. Also, the kohler had an electric clutch. The briggs did not.
Now I am trying to retrofit a clutch onto the briggs 1" shaft, making sure to match the pulley sizes from the kohler.
Obviously, I can't use the kohler setup on the briggs because of the different shaft size.
But I am having to match up pulley size and location on shaft to ensure proper operation.
My question is can I install an electric clutch on this engine that previously did not have one? Any tips or tricks would be much appreciated!
