ThatOneGuy1968
- Oct 3, 2023
- 37
I have aquired a Murray Select riding mower with an 18.5 Intek..
Model 33R7770003G11411..
Model on HOP sticker is #960440008..
It also shows to be a model MS18542.. CONFUSING!!
Well it needs a compression release and I’ve already recently change a cam in a different intek motor..
I picked up the tractor and the gear shifter is a miss and the the bottom of the shifter is a linkage to the transmission.. there is a turn buckle taking the place of the linkage..
I can’t get it to roll.. not sure where neutral is I’ve tried repeatedly hacking the shifter back and forth sounding and looking like I’m changing gears, but I can’t find neutral.. I tried the first shift pouring on the trans by hand.. can’t move it by hand or screwdriver..
The witre that you pull to “(release??”) / unlock the rear end moves the lever it connects to when the brake is set.. won’t roll.. release the brake and the lever with the wire closes.. (won’t roll)
Hold the lever out and take the bake off.. (won’t roll..
Help..
Help..
