It also can be the wrong kinda of heat. You must heat fast and localized as you can. Otherwords a propane bottle torch just won't do.
It is sorta like the silver solder job I did a couple days. Using a different stronger silver solder a propane torch just barely soften the solder although the rest of what was heated was nearly hot enough. I switch over to my ACE/Ox welder and it immediately melted and seeped into the joint. I using 45% silver solder due to high vibration joint area on a compressor.
And if you are good you can even use ACE/Ox torch to cut pulleys off without damaging the metal shafts and the seals.
