crazy charlie
- Nov 18, 2018
- Threads
- 14
- 90
I own 2 old Toro mowers.A recycler GTS2 and a GTS5 OHV ,Mowers look almost identical except that the Recycler with the GTS2 motor reads "Toro" on it. Both have same brand plug with twin electrodes, one is a 12 and the other is a 22 with significantly longer reach head on it.Totally different plugs....totally different.The Recycler gts2 Toro motor has the 12 plug and is never easy to start and often runs for 5 minutes and then cuts off and restarts easily in 5 mins. The GTS5 with the 22 plug starts pretty easily and keeps running as long as I need it to.ID tags are long gone with age .Confused with plug differences and assuming the recycler may've incorrect plug...???? Anyone???? Thanks Charlie
