Everything works now. New switch identical, even the old key works.
mcostello Active Member Joined Jun 10, 2012 Threads 10 Messages 71 Jan 9, 2024 / Kohler engine no spark till coasting. #61 Everything works now. New switch identical, even the old key works.
T TobyU Well-Known Member Joined Jun 1, 2014 Threads 0 Messages 587 Jan 9, 2024 / Kohler engine no spark till coasting. #62 mcostello said: Everything works now. New switch identical, even the old key works. Click to expand... Then as I mentioned .... the old one wasn't functioning as intended. It was losing a connection in the start position.
