Moparjoe499
You are correct Shady. In a partially filled tank, the air does not 'come in' overnight. What air is in the tank remains until more contents is used. Ethanol absorbs water in the fuel and condensate and remains at the bottom of the tank with it. Don't totally empty a partially filled container into your small engine. Always use a funnel with filter to take out the lumps.
Its freakin gasoline. It has 10% alcohol in it. Any condensation will be burned in the cylinder. Anyone who cuts grass often enough will buy gasoline often enough that the can won't get any water in it. Stop leaving your damn freaking gas can outside. I have ran across this problem before and people wonder why their mower won't run. Stupid people never learn.From you other long post here, it sounds like you have a lot of knowledge about how gasoline (more, it's the ethanol) attracts water. I don't agree w/you that covering a vented gas cap completely with plastic wrap & then rubber bands won't keep moisture out. It HAS to.
I, unfortunately, thought I bought enough gas to completely fill the tractor tank; but, it didn't & I am a gallon short. I was just tired & cold, & decided to simply leave it this way. According to some of the posts, a tractor gas tank holds such a finite amount of gas, it doesn't make a great deal of difference. Prior, I added Seafoam to the gas, ran it a few minutes, so don't you believe it will prevent rubber & carb damage over the winter?
