Tracking adjusted (by dealer) to track straight, with control arms full forward, the mower will not track straight when backing up, both sticks full reverse. Control arms are even while in neutral. When on jack stands, wheels do not turn with engine running and in neutral. Brakes are not dragging on either side.
I have another zero turn (Grasshopper) which has seperate pumps and Parker wheel motors, and tracks straight, full speed forward or reverse.
Dealers 'mechanic' says this is normal; than none of the Hydro-Gear integrated units track straight both forward and reverse. I called Hydro-Gear, and they say otherwise.
So, do any of you have a Maverick HD, or any other BB mower with Hydro-Gear 3200 or 3400 integrated units? Does it matter to you if they don't track in reverse?
