Troy-Bilt 4 cycle backpack leaf blower has no high rpm
Tiger Small Engine
  • / Troy-Bilt 4 cycle backpack leaf blower has no high rpm
Being this blower is a splash system are there ways to prevent the problem from happening?
This is a back pack blower and I would think not much tilting goes on compared to a trimmer.
The term, “polishing a turd” comes to mind with this unit. You paid $40-$50 bucks initially, and are talking about possibly a short block for another $110. The unit is worth probably about $75-$100 all in used running 100% correct. If you want to satisfy your curiosity and experiment, have at it. If you want a good solid blower that will perform great, and run virtually trouble free for years to come, buy a Stihl, Echo, or Husqvarna.
Richie F
I have a Husqvarna 150BT I've been piecing together also. It does run but spark plug hole needs a heli coil (which I have).
If you know anyone I need the air filter cover gasket and outside cover for it.
Richie F
OK here's what I did to make this Troy -Bilt run.
Changed out the oil to 10W40 that I had on hand and did the math of adding STP to it.
That's 3oz of oil to .6oz (one tbsp) of STP. Really wanted to use Lucas but at $17 a quart, nope.
The original main jet (Walbro #76) is .013 I had an extra carb so I drill that jet to .014.
Put in a new Champion plug #RDZ4H/979, had an original plug (Chinese?) #794-00082.
Let it warm up and it runs low and high like it should. No oil smoke and doesn't fowl the plug.
I hope this helps someone.
Tiger Small Engine
So you drilled out a carburetor jet .001” (one thousandth of an inch), through in some thicker oil, and changed out the cheap Chinese spark plug to a Champion, and now everything is great. Hard to believe, but glad you got it running.
Richie F
Me too.
Now I am confused.
First you drilled out the jet in post #1
"On the OEM carb drilled out the main jet from .013 to .017 and I can get high rpm but not to spec."
And then you said you drilled out a second carb jet.
"The original main jet (Walbro #76) is .013 I had an extra carb so I drill that jet to .014."
Why would only now going from .013 to .014 works when going to .017 didn't work?
Richie F
Now I am confused.
.017 over jetted the carb, plug was black and couldn't get full RPM.
.013 I had idle but no high idle.
.014 Was the jet size to run without fowling the plug and get full high idle RPM.
Adding a fresh plug helped also.
Putting in thicker oil with a little STP, more than likely helped with compression, though I didn't confirm that.
This is why you don't get to aggressive resizing jets. You have sneak up on the right mixture.
Normally jet are in hundredth of a millimeter. But it sound Walbro might using a different system as #76 would had been .0299" if they were using a standardized system.
I would like to know the Walbro carb model number so I can contact Walbro about the jet sizing.
But would have thought MTD would be using a Ruixing carb clone of a Walbro.
Richie F
I've contacted Walbro and they were no help.
The letters on the carb are WYLB. There is a number 413 and letters THAI or THA1 on it.
Larger Walbro carbs on say mopeds might relate to a #76 jet that is .0299
I'm a retired auto mechanic of 52 years and am familiar with jet sizing on different carbs, but I could not find a chart for jets for this carb.
I did find the Walbro original carb was a 75205676A and was updated to 753080025, these are MTD carb numbers.
Hmm it looks Walbro has change their website for the worst. It only list six WYLB carbs going from -1-1 to -6-1 and no ipls. Companies just keep trying to shove stuff down the good techs throats.
I was once to look up about everything for these carbs. Now it a major guessing game.
