I have an old YTH23V48 that I leave in storage with the snowthrower attachment in place for winter use. I start it up once a month to stay on top of any issues.
This month, she wouldn't start for me. Cranks fine (battery is holding a full charge). Won't turn over. I notice the fuel filter is dry. Swap out the fuel filter and fuel pump. Try again. Still nothing. Looks as though no fuel is flowing through the line to the filter, pump, and engine. There's a solid gallon+ of fuel in the tank. The line from the tank to the filter is clear and flows in both directions if I blow or suck on the hose.
Could it be the vacuum isn't creating enough "pull" to draw fuel through the hose to the filter and beyond? If that's the issue, does anyone have a suggestion on next steps to resolve the matter?
Am I overlooking something else that could be the cause here?
Appreciate your thoughts in advance.
Jeff
Jeff
