Tiger Small Engine
- Dec 7, 2022
- Threads
- 3
- 1,655
How did you drain the units? Drain plug, turning them upside down, extraction with a pump? This process should not take that long, nor does it have to be exact. Go through purging process with bypass open and closed, add oil until full.Yes Thank You- I have the link saved, & have verified my serial numbers as internal expansion unit. It seems my pertinent info & chart begins on page 10 & onward..
Says fluid capacity is 77.23 fl oz for each unit only. But this is also for External expansion units, even tho it is clear it lists this as for the hydro unit alone.
I only drained a total of 118 fl oz outta both combined. Not counting oil filters soaked media.
