Hydro gear oil and filter kit
RBobo
I have a Z-Force L 60” zero turn. I need to know what hydro gear oil and filter kit to get !
Well going to need the actual mower model number from the serial number tag to lookup which hydros it has. But it should a common filter and oil package. Just need the hydro model number to look them up on Hydro Gear dealer site.
RBobo
The hydro gear model # ZH-JGBB-3KDB-36LX
RBobo
Okay the kit is 72750 but if your unit does not have external tanks then you will also need the 55752 fitting as the kit only supplied with a single port fitting. Dual port is so you when the units are filled properly.
Kit contains 5 quarts of oil and 2 filters with pump and hoses.
Also here is video on how to do the oil change.
RBobo
Dear Star Tech , thank you so much for a quick answer to a question I’ve been searching for hours the last 2 days !! My model does have the exterior reservoir tank. My mower works ok until it gets hot ( running for over an hour) then gets where it looses power to turn or go at speed. The mower is about 5 years old and hasn’t been trans serviced ( my bad). The fluid does look dirty. I have watched lots of videos and am familiar with how to do the hydro oil and filter change. Been a maintenance man for 45 years so I am somewhat mechanically inclined but this computer stuff drives me crazy with information overload!! Anyway thanks and have a great day ! I’m hoping this will help my trans last a while longer !!
