compression release cam
TomMcmullen
Mod# 31R977 0052G1 Purchased mower 6/2018 120 hours and compression release cam broke. B&S says out of warrantee and no service bulletins on it. It will start by rotating by hand counter clockwise to give it a running start. Is it unusual for it to break so soon? Is B&S correct. Anything I can do? Thank you
Read the fine print when ordering, if description does not include B&S do not order part.
Use OEM B&S Parts. Adjust valves engine cold to specs. in Operators Manual above page 9. Let us know how it goes, thanks Mark
Original part # 793880 has been superceded to 84005207.
How do you know it's the CR? Are the valves adjusted properly?
Same thing happened to my Husqvarna with 18 HP B&S. Finally got tired of spinning the flywheel and had it repaired. Total cost $560 which included some other minor repairs. So far --so good.
Yes its common thing on B&S. Replacing part is only solution .
