Kawasaki Carburetor Electrical Connection
JMACDATHIRD
I installed a15003-7081 Carburetor Replacement Fits Kawasaki FH580V , but the Electrical connection on the bottom of the Carburetor has a 'RECTANGLE' Shaped female connection. Whereas the wire for the replaced Carburetor is 'SQUARE' on one end and sort of 'ROUNDED' on the other end. What can I do? See photos. Thanks.​
It will fine. But before you plug it in close the gap on the terminal on the RH side of the posted image as it will be a loose connection otherwise. And it doesn't matter which way it is inserted as the solenoid will work either way.
JMACDATHIRD
Thanks for taking the time to help me, it worked just as you said.
Mat 10:41 He who gives honour to a prophet/preacher, will be given an upright man's reward.
