hello if anyone can help would be great... mower running fine no issues.. ran over a tarp mower died would not start.. replaced safety switches, batter, starter, solenoid.. tested key switch
on testing the solenoid
power side 12 volts
white wire 12 volts when trying to start
black wire circuit good
starter side nothing.. got 12 volt once with a big click ..
also to note the amp meter does not seem to work
I used a car battery directly jumped the starter and mower ran fine for over 1 hour .. turned it off would not start again. i am guessing running over the tarp shorted something not sure what
maybe a ground? if anyone had a similar experience may know what to do next
power side 12 volts
