Troy-Bilt TB525CS Feels Locked Up When Trying to Start
Rick0124
  • / Troy-Bilt TB525CS Feels Locked Up When Trying to Start
Did a search but didn't find anything about my problem. I have a Troy-Bilt TB525CS trimmer/tiller/pole saw. It ran fine a few months ago. Now when I pull to start it, it feels locked up. l removed the plug and it pulls smoothly. The more I screw the plug back in, the harder it is to pull, until it finally won't move. I'm wondering if a valve is stuck shut. Appreciate any comments or suggestions, thanks!
May just be the valves are need adjusting on that AC3 engine.
A compression test will help point to it if reading are too high.
The valve clearance for this engine is 0.003”-.006”(.08-.15 mm) for both valves.
Rick0124
Great information, thank you!
