Finding old parts
AndyK
Cannot find a mower blade adapter for an old Rally mower. Model A126CR Lot: 0888M Serial: 012722 Briggs 3.5 hp Model: 90702 Type: 3090-01 Code: 88031724
Any suggestions? THANKS much!!!
Measure length, width, and hole bore size and find the blade that way.
Thanks for the replies. Where would be a good place to look for a universal adapter that would work? I’ve tried several different websites with no success. THANKS!!!
Bought this adapter - as indicated, it didn’t work. I believe this mower was from around 1982.
Thanks again for any suggestions.
That blade adapter is 1.19" x 7/8" Inside Dia. so it is for 7/8 [.875] crankshafts. You must measure the crankshaft that you trying to fit the adapter on to even start looking a compatible adapter.
Maybe these pictures will help. THANKS again for all the assistance.
