Was curious if anyone else had the same problem. If so how was it fixed. Should there be 12v at the connector for the meter ? Thanks.Forget the phone, you need to talk with them face to face.
when you say "just got", ? ? How long ago..., did the hour meter register any hours at all; and if so, what is it showing? If your dealer gave you that bs response I'd load the thing up and take it right back to them, since you can probably expect that same kind of service on anything else.....Just got a 2023 ariens 918005 zero turn. The hour meter does not work. Contacted ariens and was told to call the store where I purchased from. They asked if I bought their extended warranty. I said no. They said they said they can't help. Contact ariens.
Just got it less than 10 days ago.when you say "just got", ? ? How long ago..., did the hour meter register any hours at all; and if so, what is it showing? If your dealer gave you that bs response I'd load the thing up and take it right back to them, since you can probably expect that same kind of service on anything else.....
Have you talked to the owner of that dealership?Just got it less than 10 days ago.
That's crazy, lowes put mine together wrong. I had multiple problems and they just said lowes was to blame. Put my seat on wrong, so I was sitting on the engine shroud the first couple hours. Foot pedal for deck lift backwards. Also the "roll bar" was bent so one of the screws isn't in there. It freely moves back and forth and squeeks.I bought an Ariens Ikon 52” last year and it Arrived with a cracked cup holder. I registered the mower as soon as I got it. I called Ariens customer service and the nice lady looked up my mower and said, “no problem, we’ll send a new one”.
Did you register the mower when you bought it?
Worst case scenario, buy a new hour meter, install, and go back to dealer with a bill for part and labor. Depending upon they react, find another dealer for future service and leave a negative review on their website.That's crazy, lowes put mine together wrong. I had multiple problems and they just said lowes was to blame. Put my seat on wrong, so I was sitting on the engine shroud the first couple hours. Foot pedal for deck lift backwards. Also the "roll bar" was bent so one of the screws isn't in there. It freely moves back and forth and squeeks.
