oldackonoak
I have a Husqvarna YTH2448 I took the transmission out this spring and welded the broken mounts. I put it back together and it ran great. I punctured an axle seal I replaced that added missing oil and had very low speed in forward. Reverse is great. I thought I had over filled it. I took it out again this morning took some oil out and bled it for any trapped air. Put back together and I still have the same problem. Belt is new pulley are good. I goes in reverse very well and when I go forward it barely moves. I have tried the bleed method with the tractor running and still I have nothing in forward. Any advice would greatly be appreciated I have been working on this tractor since spring on and off.
I don't want to completely drain the oil it isn't cheap. Oh it is a Tuff Torq transmission k46 same as Craftsman and other AYP tractors.
Thank you in advance for any help I will try anything at this point.
