Turbodriven
 - Aug 18, 2023
- Threads
 - 11
 - 84
Kohler command pro 27. After warming up the mower I get about 160 PSI in both cylinders with my compression tester. But then, when I pressurize both cylinders to 50psi at TDC (poor man's leak down test) I get air hissing and escaping through the oil fill tube (cap off). Pretty fast actually, it even blows a little smoke/vapor out during this.
Have you seen this before? Is there another way this could be happening besides rings (or maybe head gasket?) on this motor? I didn't notice any noise through the exhaust or through the intake. So valves seem good. It's the good compression readings that have really thrown me off here
Just for reference, its a Gravely 260Z with 1200hrs, and the motor is bogging under medium and heavy loads. Motor starts easy and sounds great at rest or light loads.
