B&S Model 92202 3.5 HP Fuel Tank?
seagiant
Hi,
Trying to get a 3.5 HP up and running on a Edger.
Does this tank have a inside compartment for the short pick up to pull from for the pulsa jet carb???
If you have a pulsajet carb it’s more than likely there is a small auxiliary tank inside the main tank. It would be much easier to answer your question if you would supply us with all engine numbers.
Hi,
Thanks, It is a 2 quart.
Got a strong light and can see where it broke off!
Looking for a local used part now!
Hi,
I don't see anything available new?
How are you guys keeping these older motors going as far as parts?
Hi,
Well...Called a Dude I know that owns a Lawn Mower Shop and asked about a used Tank in the Junk Pile.
He's busy of course so went over and found a B&S Model 91212, Type 1319 E1.
It was on an MTD Edger missing 2 wheels, and looked pretty good, asked what he wanted and he said, take it!
Sooo...Going to clean it up and have a look.
If I can get it running, will put it on the more stout McLane frame and call it good!
I take it, that this Engine is a "Kool Bore"?
