tomsariens
- Aug 17, 2023
- 7
Should the hour meter turn off when my key is off on 2023 Ariens Ikon 918005 zero turn mower? Mine stays on and I'm concerned that may be weakening my battery.
The meter should turn off when not in use. I contacted Ariens about mine and they stated that yes, the meter should go off. Mine was still under warranty so they fixed the problem with replacing the meter with a new one and installing a new key assembly that cuts off that circuit when I turn it off. Haven't had a problem since.Should the hour meter turn off when my key is off on 2023 Ariens Ikon 918005 zero turn mower? Mine stays on and I'm concerned that may be weakening my battery.
I’ve owned two Gravely ZTRs and the hour meter is always showing the current hours. The elapsed time doesn’t change until the mower is running. The hour meters have an internal battery. When those internal batteries fail, a new hour meter will need to be installed.The meter should turn off when not in use. I contacted Ariens about mine and they stated that yes, the meter should go off. Mine was still under warranty so they fixed the problem with replacing the meter with a new one and installing a new key assembly that cuts off that circuit when I turn it off. Haven't had a problem since.
Thank you. I will contact Ariens and, hopefully, have the same result as you. Did you have to take your mower to the Ariens dealer or did they send someone to you?The meter should turn off when not in use. I contacted Ariens about mine and they stated that yes, the meter should go off. Mine was still under warranty so they fixed the problem with replacing the meter with a new one and installing a new key assembly that cuts off that circuit when I turn it off. Haven't had a problem since.
I honestly think that you are wasting your time. Like I said, they are designed to stay on.Thank you. I will contact Ariens and, hopefully, have the same result as you. Did you have to take your mower to the Ariens dealer or did they send someone to you?
I own 6 2019 Ariens Commercial ZT Mowers and each has been upgraded for a key circuit shutoff when you turn off the ignition. By doing this I don't have to pay for battery backup.I honestly think that you are wasting your time. Like I said, they are designed to stay on.
We do not know what make and model of mower POW123 has or had.
Hour meter on Gravely HD question
I just got my new Gravely HD 48. One thing I was wondering about is the hour meter, I noticed it doesnt turn off, it just constantly displays the hour count. I am concerned this will drain the battery over time. Is this normal for it not to turn off after a short period of time? I checked it...www.lawnmowerforum.com
