Used to crank hard, burned up the starter, new starter works great though, was a free mower, and I'm sure it was run with little or no oil because the valve cover leaked bad onto the muffler after i filled the oil, Fixed that and noticed under the fuel tank was now more covered in oil, I figured it was blow back from the valve cover seal leaking, it wasn't. I'm wondering if I need to take the case apart and repair something, other than the hole, or just bring it back to where I got it?
