E-Clip
Butch Bridges
The e-clip is missing from the engine end of the push rod on my Poulan Pro PP19A42. I need to know the size so I can go to the hardware store and get another one.
Grab a caliper and measure the shaft. Subtract a 1/16” from your measurement and you have your size.
More likely it is a 8 mm push nut if no groove or a 6mm if there is a groove for it.
The mower's ipl lists the 8 mm push nut but the General Transmission RS800P IPL lists a 6mm e-clip.
Butch Bridges
I used an electronic caliper and it showed .09 inches. So is that like 1/4 inch or 3/8 inch or 7/16 inch or what?
Butch Bridges
The mower's ipl lists the 8 push nut but the General Transmission RS800P IPL lists a 6mm e-clip.
It has the grove
You need to remeasure as your reading is less than 1/10 of an inch.
