TEToffensive
I purchased a used Gravely proturn 452 with yamaha 775v-efi from a Gravely dealer it was on consignment. only 71 hours. seems clean and took care of. DOM Nov 2019. owner was downsizing equipment and kept larger mower. I got it home and cut grass for approx 1 hour and large white smoke trail came from exhaust for about 2 minutes then quit. Was told probably from daily 2 minute runs in am and then again pm dealer moving it from shop to street and back to display it. Had no more issues and put 5 hours on meter. Now to problem, this mower has two red lights on right side close to start and throttle. one is oil pressure, the other (according to downloaded owners manual ) is an engine malfunction light. Manual says if light comes on stop and check engine manual. Ariens/Gravely has provided what appears to be standard Yamaha manual. No where in manual does it mention malfunction light. Called the local dealer and they were unsure as they don't see too many of the Gravely with Yamaha motors, thought it was a charging system light to let you know it was charging. Called Ariens/Gravely help center as soon as it opened and wonderful telephone agent took notes and said they would send to technician, and they would call back. 9 hours later and after help center closed, still no call. I cut grass today about two hours and light flickered, but couldn't watch it constantly. Didn't have any issues. Anyone know what the light actually is, what does it mean and where can I find something that tells me? Have heard there were problems with this engine (after I purchased it. 5 year extended warranty in effect 1 year to go.
